Автор Тема: Moskvich 21412 - Aleko из Болгарии  (Прочитано 24192 раз)
Оффлайн aleko driver
« Ответ #40 : 02 Декабря 2009, 20:58:20 »
Капот tuning
Aleko 21412 1480 cc
Оффлайн DampirTBs
« Ответ #41 : 02 Декабря 2009, 21:36:46 »
Good job) What the material?
« Ответ #42 : 02 Декабря 2009, 21:54:59 »
microporous rubber
Aleko 21412 1480 cc
Оффлайн Антонио
« Ответ #43 : 09 Декабря 2009, 08:56:23 »
Цитата: "ПапараЦи"
Цитата: "aleko driver"
we use Samara's "вакуумный усилитель тормозов" with lada "main braking cylinder" and connect to the system 😀.
it's perfect, but how you connect it to M-2141?  😝
https://autoclub.tomsk.ru/viewtopic.php?t=1211
Comments are necessary?
aleko driver, the class device. Colour as at me. A spoiler native?
In connection with very bad quality of let out spare parts, there was a question: and how to be with brakes? Business that responsible …
As it is known, the most part of the repair complete sets which are let out now for native MBC, very quickly become unfit for use. Rubber of which do poor quality cuffs, besides in most cases it has rough edges!!!
If to buy MBC (the main brake cylinder) in gathering it is possible to get in the same way on the poor-quality goods. Here for example, MBC firms FENOX (at least those which were got for last year) have very unpleasant property. In due course they start to pass a brake liquid between working chambers – in communication by it the pedal becomes "soft" and dynamics of braking considerably worsens. Besides after even small time interval the brake liquid starts to proceed through back cuffs and gets in the vacuum amplifier!
The charter from this problem and having carried out the situation analysis, our expensive clubmate has decided to replace all the same the MBC with something more reliable and qualitative... Namely to it it has been decided to establish MBC + the Vacuum amplifier from VAZ-2108. To me honour to help it in it not easy business has in turn dropped out
Why VAZ-2108 - because is the most widespread and checked up system on cars of a similar class, besides for VAZ-2108 in the market there is a weight of details of import manufacture!
In general MBC М2141 and MBC ВАЗ2108 on fixture not the interchangeable. Therefore it has been decided to change and the vacuum amplifier of brakes. Seats at «вакуумника» from 2108 do not coincide with apertures in motor board М2141. Moreover, at VAZ-2108 the vacuum amplifier fastens two bolts, and at М2141 – four!!! From here the conclusion – is necessary any adapter. The arm of the vacuum amplifier 2108 does not approach since its fastening to a car body does not coincide with Moskvich-car. However the variant has been found quickly enough – there almost as native there is an arm of the vacuum amplifier from VAZ-21213 (Field). It is just calculated on the vacuum amplifier 2108 and thus has precisely same fastening to a body as in М2141.
All that needed to be made, it to truncate it on length. It is for this purpose cut it (the photo see) and having cleaned an average part it is welded two halves together. The original transitive plate turns out.
Then it is necessary to truncate a rod of the vacuum amplifier 2108. It can be made in two ways: to cut off and weld measuring length in a place; or to make as on Moskvich, i.e. on the end of a rod a carving long 3-4см, and the tip is simply screwed on it being fixed by a counternut, it allows to change length of a rod already directly during operation.
Konst has chosen the second variant, therefore we measured length of a rod of the native vacuum amplifier (till the end of a carving) and have sawn off at size a rod at the new. Then on a rod (its thickness somewhere 11мм) has been cut carving М10*1,5, and in a tip the regular aperture has been expanded to 9мм. Also the same carving is cut.
Further it is necessary to collect all simply. One of contours new MBC is necessary for muffling (a bolt or reliably muffled tube). After assemblage, naturally, it is necessary to "pump over" brakes anew.
Eventually the result of has justified!!! Brakes became really more агрессивнные and "lungs"...
You at yourself similar did?
Оффлайн ПапараЦи
« Ответ #44 : 09 Декабря 2009, 17:14:25 »
Thanks!
Мой фотоархив тут: https://paparazi.photofile.ru
« Ответ #45 : 10 Января 2010, 00:06:30 »
This is the new driver on the car  :tongue:
Aleko 21412 1480 cc
Оффлайн ivan_77
« Ответ #46 : 10 Января 2010, 00:50:16 »
Respect for beautiful draver and her car 😆 aleko the best!!!
Москвич дв ваз2106 1999гв
Оффлайн NeoShaMAN
  • овасч
« Ответ #47 : 10 Января 2010, 01:15:53 »
International dialogue it's cool!  :mbounce:
Fans of Moskvitsh are worldwide!  :clap:
respect your car and your girlfrend 😀
Excuse for my English, i only own german and russian languages
diana
« Ответ #48 : 10 Января 2010, 23:07:30 »
Оффлайн buddaonline
  • Карма: 13
« Ответ #49 : 11 Января 2010, 01:17:41 »
Hello, crazy bulgarian owners of mad cream russian atomic submarine! 😀
Nice driver and nice car, i wish you to be careful and smart for all road travels!
Оффлайн takashi
« Ответ #50 : 12 Января 2010, 14:57:15 »
Nice car!!! 👏
Мащинка с движкой ВАЗ 2106
Так же Мы в контакте https://vkontakte.ru/id19307191
Севастопольский Москалик https://www.akoulina.ru/viewtopic.php?t=19181&postdays=0&postorder=asc&start=0
Оффлайн женек на 214145
  • Карма: 65
« Ответ #51 : 12 Января 2010, 15:26:53 »
В английском не силен, а зачем капот резиной делать?
названия запчастей порадовали 😆
Москвич хороший береги его.
ЗЫ. Если сможете переведите человеку, самому лень 😝
АЗЛК 214145 "NEON" R.I.P.
Hyundai Getz 1.4;
Renault Sandero - продано;
Оффлайн Shrieck
« Ответ #52 : 12 Января 2010, 15:34:12 »
I'll try to translate....
My english is bad, why you use rubber on a hood?
Names of car parts make me smile 😆
Mosckvich is good, take care of it.
ЗЫ. If you can translate him, I'm too lazy 😝
Плюнем, и пойдём... (c)
  • Карма: 65
« Ответ #53 : 12 Января 2010, 15:35:41 »
Shrieck ахахах, вот спасибо 🍺
Hyundai Getz 1.4;
Оффлайн Magikan
  • я был когда-то...
  • Карма: 68
« Ответ #54 : 12 Января 2010, 15:55:27 »
car and girl very good )))
i wanna come to Bolgarie, i think, i do this summer... mb with my car
sorry for my english
diana
« Ответ #55 : 13 Января 2010, 21:19:06 »
микропористой резины и для снижения вибрации и шума автомобилей (к сожалению, не владеющему русский) и выражает благодарность за теплые слова. Скоро я напишу ретро-темой для 408-Автосервисы. Сейчас диска Алеко. поздравили  👼
diana
« Ответ #56 : 13 Января 2010, 21:28:22 »
Мы будем рады видеть Вас и обмениваются идеями и опытом
« Ответ #57 : 13 Января 2010, 21:35:33 »
обмениваются и водка конечно  😆
Aleko 21412 1480 cc
Оффлайн Алексей Криво Ручка.
« Ответ #58 : 13 Января 2010, 21:39:43 »
aleko driver
Россия это не только  водка, и голый паба.
Москвич 2141,1,5УЗАМ
« Ответ #59 : 13 Января 2010, 21:49:18 »
Цитата: "Aleko"
aleko driver
Не то, что я имел в виду. В Болгарии, продал поддельной водки, и его коллегу, если он может принести нам хорошую русскую водку, и мы дадим ему попробовать Болгарский
Aleko 21412 1480 cc
